BGP command nei next hop self between IBG neighbours
mahesh18
Level 6
Level 6
Hi all,
I have this BGP setup
R1 -----------R2 ---------------R3----------------------------R4
R3 and R4 are EBGP neighbours.
R1,R2 and R3 are in same AS  and are IBGP neighbours.
As we know that R2 will not advertise the routes learned from R3  to R1
so i have config this on R2
neighbor 100.100.100.100 route-reflector-client
R1 loopback 100.100.100.100
R2 loopback 2.2.2.2
R3 loopback 6.6.6.6
When i config the command on R2 below one
neighbour 100.100.100.100 next hop self
Now i do the sh ip bgp on  R1
R1  does not show next hop as 2.2.2.2 it shows next hop as R3 loopback address which is 6.6.6.6
I need to know why next hop self does not change the next hop on R1?
Mahesh
2 Accepted Solutions
As far as I understood 100.100.100.100 is R1 ip.
R2 is the RR.
R2
route-map reflector
set ip next-hop 2.2.2.2
if 2.2.2.2 is the ip with whom R1 establish it's adjacency
router bgp 6500
nei 100.100.100.100 route-map reflector out
end
clear ip bgp * soft
Dan
It applies all the rules configured on route-map to all prefixes advertise to that neighbor.
In your case , it will change the next-hop of all routes advertised to R1.
Here is a link , for futher reading :
http://wiki.nil.com/BGP_route_reflectors
"The next-hop-self neighbor configuration parameter or (most of the) set options of outbound  route-map configured on route-reflector clients are ignored for reflected routes. BGP next-hop can be changed set ip next-hop route map command ( BGP next hop propagation feature introduced in IOS release 12.2)"
Dan
10 Replies 10
John Blakley
Mahesh,
Did you try clearing the peering between R2 and R1? You should be able to do a soft reset.
John
HTH, John *** Please rate all useful posts ***
Hi Mahesh ,
You cannot change the next-hop of the route with "next-hop self"  on a RR to a route-reflector client
If you want to change it you must use a route-map and set ip next-hop , and apply the route on the out of the neighbour.
Dan
Hi Dan,
Thanks for reply.
You mean that on R2 router i can config this
router bgp 6500
route-map reflector
set ip next-hop 100.100.100.100
Let me know if this is right way?
Mahesh
R2 is the RR.
R2
route-map reflector
router bgp 6500
end
clear ip bgp * soft
Dan
By tthe way when you are setting the next-hop as it's own IP , you will get an warning. Do not worry about it
Dan
Hi Dan,
It worked fine now.
So just last thing what does command  nei 100.100.100.100 route-map reflector out do?
Mahesh
Dan
Hi Dan,
Many thanks for reply back.
Mahesh
My pleasure , Mahnesh.
Dan
Hi John,
yes i clear the routes by clear ip bgp *  on both routers.
Mahesh
