BGP manual Next hop modification
hi all, i read somewhere that we can use manual next hop modification in BGP instead of using next-hop-self command, how can we do that ?
1 ACCEPTED SOLUTION
Re: BGP manual Next hop modification
Ovais,
You would apply a route-map outbound on an iBGP neighbor as follow:
router bgp xx
neighbor x.x.x.x remote-as xx
neighbor x.x.x.x update-source lo0
neighbor x.x.x.x route-map set-nh out
route-map set-nh permit 10
set ip next-hop
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
1 REPLY
Ovais,
router bgp xx
set ip next-hop
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
285
