bgp neighborship
Once the bgp neighborship comes up, then does the bgp router send its bgp table to the peer OR does it send the bgp known routes in the IP routing table to the peer?Could an expert clarify this for me?
1 ACCEPTED SOLUTION
Purple
bgp neighborship
The Router sends the non filtered best paths installed in the BGP table and at the same time it installs these best paths in the RIB if they are not known from other source with a better(lower) administrative distance.
Alain
1 REPLY
Purple
bgp neighborship
Alain
101
