01-17-2014 09:58 AM - edited 03-07-2019 05:38 PM
I have a stack of 3750-x switches, i recently purchsed an IP services license upgrade per switch in the stack so i could run BGP. The license install was successful and it now says the license level is ipservices, however when i try and configure BGP it still says 'protocol not in this image'. Please advise urgently
software image is
12.2(55)SE4
output of 'sh ver'
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 12.2(55)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Sep-11 02:09 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
XSHQ001-3750-STK001 uptime is 22 minutes
System restarted at 17:34:46 UTC Fri Jan 17 2014
System image file is "flash:/c3750e-ipbasek9-mz.122-55.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-48P (PowerPC405) processor (revision B0) with 262144K bytes of memory.
Processor board ID FDO1523K0XB
Last reset from power-on
6 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 30:E4:DB:36:6E:00
Motherboard assembly number : 73-12553-05
Motherboard serial number : FDO15240637
Model revision number : B0
Motherboard revision number : C0
Model number : WS-C3750X-48P-S
Daughterboard assembly number : 800-32727-01
Daughterboard serial number : FDO152404C8
System serial number : FDO1523K0XB
Top Assembly Part Number : 800-31324-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMJZ00ARB
Hardware Board Revision Number : 0x03
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750X-48P 12.2(55)SE4 C3750E-IPBASEK9-M
2 54 WS-C3750X-48P 12.2(55)SE4 C3750E-IPBASEK9-M
Switch 02
Switch Uptime : 22 minutes
Base ethernet MAC Address : 64:00:F1:55:D1:00
Motherboard serial number : FDO150814NV
Motherboard revision number : A0
Daughterboard serial number : FDO1508063D
System serial number : FDO1508R0J6
Top assembly part number : 800-31324-02
Top assembly revision number : A0
Version ID : V02
License Level : ipservices
License Type : Permanent
Next reboot licensing Level : ipservices
Configuration register is 0xF
01-17-2014 10:20 AM
Ricky
Your output is still showing IP Base. From your output ie. the bottom line -
you need to reboot the switch for the license upgrade to take affect.
Jon
01-17-2014 10:57 AM
Jon,
thanks for your swift reply. Regardless of the feature set, apparently that IP base version does not support BGP. I installed a Universal-K9 image on there and then rebooted and now everything appears to be fine
thanks again
