Block access from other subnets 2921 router
Roger Richards
Good day,
I have a 2921 router...
I got many subnets on network.. What I want to do is block access to one of my networks and allow all other subnets to browse the web.
I have;
192.168.4.0/24
10.20.50.0/24
10.20.40.0/24
10.20.30.0/24
10.20.60.0/24
I want to block access to 10.20.60.0 from all other networks while allowing them to access the internet
16 Replies 16
John Blakley
We may need more information. Are you wanting to do this on the router? Is the router split out into subinterfaces or are all of these subnets on one interface? Are these subnets on the lan or wan side? Do you have a L3 switch?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
JohnTylerPearce
Level 7
Level 7
My first question is, do you have any webapps that users use? Or would any site they visit be on the Internet?
The reason why I ask, is this could be done pretty quick.
Also, how are the interfaces laid out? Do you have a single inside LAN interface and an outside WAN interface?
Jon Marshall
John's
Have to nip out but it is subinterfaces on the LAN interface of the 2921 for each subnet.
No L3 switch inter vlan routing. 2921 connected to internal L2 switch on LAN and WAN interface connects to ASA inside interface.
Over to you
Jon
Lol! What? How did you get all of that from this post??
HTH,
John
Jon,
This is a John only thread, please remove yourself. We don't need and "Jons".
There are a lot of John's here
HTH,
John
John
Message received and understood. I'll just quietly disappear....
Jon
I thought it was pretty obvious myself
I helped Roger reconfigure his network in a a couple of rather long posts a while back so i remember it.  Come to think of it not sure about the 192.168.4.0/24 network being a subinterface so i'll check one of the posts.
Jon
If what "Jon" said is correct you could do something like the following.
ip access-list extended VLAN20_ACL
deny ip 10.20.50.0 0.0.0.255 10.20.60.0 0.0.0.255
permit ip any any
deny ip 10.20.40.0 0.0.0.255 10.20.60.0 0.0.0.255
permit ip any any
deny ip 10.20.30.0 0.0.0.255 10.20.60.0 0.0.0.255
permit ip any any
deny ip 192.168.4.0 0.0.0.255 10.20.60.0 0.0.0.255
permit ip any any
int vlan 20
  access-group in VLAN20_ACL
int vlan 30
  access-group in VLAN30_ACL
Now technically, 10.20.60.0/24 could still get to the other subnets, but the return traffic would be blocked.
And you could always change the permit ip any any to just HTTP traffic, etc. Depends on what you want to do.
Although it might be a better idea to configure ACLs on the firewall. It would be easier to manage that way. If traffic has to go up to the ASA to get back to the other subnets.
sorry to interupt johns,
but I would use VRF-lite feature here, just put subnet 10.20.60.0/24 into vrf and you don't have tu maintain numbers of ACLs.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Jon Marshall
Okay, here is a link to the network layout although it is not as i remember it (ie. it is't showing most of the subnets mentioned) so probably best to wait on Roger to confirm where the subnets actually are -
https://supportforums.cisco.com/thread/2264234
apologies if i confused the issue.
Jon
Thanks for that Jon You cleared the issue up, and it looks like John Tyler has given a correct answer. Technically this should be all that's needed.
HTH,
John
Think i just managed to confuse the issue.
The idea was i needed to do something else and if there were multiple posts i might not be around to reply so i just wanted to help get a quicker response for Roger.
Looking at the diagram it looks more complex because i don't think all the subnets are on the router so an acl applied outbound to the 10.20.60.x vlan/IP subnet might be easier although it's hard to say without more details.
Jon
WOW... I stepped out to lunch and got all of this  lol.. thanks for the help...  Let me take a good look at those acls...
