Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Block multicast control traffic.
Issue: 2 older machines running an application (MNR Imaging) that uses multicast to communicate.
They generate the error messages on our core switches…..
2008 Oct 20 13:33:48 %MCAST-2-IGMP_ADDRAL:IGMP: Address Aliasing for 01-00-5e-00-00-01
2008 Oct 20 13:33:48 %MCAST-2-IGMP_FALLBACK:IGMP: Running in FALL BACK mode
2008 Oct 20 13:33:48 %MCAST-2-IGMP_ADDRALDETAILS:IGMP: Multicast address aliasing: From 00-1e-0b-ec-12-b8 (155.3.2.1) on 4/3 to 01-00-5e-00-00-01 (239.0.
The problem here appears to be the destination MAC address.
The application writers have no idea how to change the application destination MAC address.
We connected the two machines to a dumb switch that is in turn connected to a C2960 that is connected to a C6500.
The intent was to use the C2960 filter the problem traffic; however, a simple igmp filter on the 239.0 range did not block the traffic causing the error messages
What am I missing and is there a better way to isolate this multicast traffic off the core switches?
No answer love for me!!
my best guess is.....
access-list 111
10 deny igmp any any
20 deny pim any any
30 permit ip any any
1 REPLY
Hall of Fame Super Silver
Re: Block multicast control traffic.
Hello Michael,
PIM and IGMP are protocols that are used to support multicast streams but multicast traffic is different then PIM and IGMP.
try
access-list 111 deny ip any 239.0.0.0 0.255.255.255
access-list 111 permit ip any any
If you are already using multicast in your network and you want to avoid that these sources register with RP (if using sparse mode)on RP ip pim accept-register
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_04.html#wp1012700
Here what happens is that sources are sending packets to a group that is not mapped to any RP so a fallback to PIM dense mode occurs and so flooding takes place.
On the c6500, or the device that showed you the log messages use
conf t
no ip pim dm-fallback
see
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_04.html#wp1013545
2) About the MAC
they are using multicast IP destination 239.0.0.1 so the MAC address is automatically built as 01-00-5e-00-00-01 and this cannot be changed.
They should try to use a unicast destination if this traffic is unwanted. The MAC used in multicast comes from the multicast IP address used.
Hope to help
Giuseppe
451
