Blocking Non VMKNIC port Veth10 with capability vxlan - Nexus100v
I am trying to configure VXLAN on my 1000v .  Everything seems ok then when I put a machine on the system uplink profile that I have configured with capability vxlan and a vmknic with a routable IP the test machines on the two ESX servers cannot ping each other
port-profile type vethernet system-uplink-vxlan
  vmware port-group
  switchport mode access
  switchport access vlan 3893
  capability vxlan
  no shutdown
  state enabled
2012 Apr 18 14:39:20 n1k-ictc-test1 %VIM-5-IF_DETACHED: Interface Vethernet11 is detached
2012 Apr 18 14:39:20 n1k-ictc-test1 %ETHPORT-5-IF_DOWN_NON_PARTICIPATING: Interface Vethernet11 is down (Non participating)
2012 Apr 18 14:39:25 n1k-ictc-test1 %VIM-5-IF_CONFIG_PURGE_AUTO: Configuration on interface Vethernet11 has been auto purged (port-profile changed)
2012 Apr 18 14:39:25 n1k-ictc-test1 %VIM-5-IF_ATTACHED: Interface Vethernet11 is attached to Network Adapter 1 of VXLAN2 on port 10 of module 5 with dvport id
2114
2012 Apr 18 14:39:25 n1k-ictc-test1 %VEM_MGR-SLOT5-1-VEM_SYSLOG_ALERT: sfvxlan : Blocking Non VMKNIC port Veth11 with capability vxlan
2012 Apr 18 14:39:25 n1k-ictc-test1 %ETHPORT-5-IF_UP: Interface Vethernet11 is up in mode access
When I look on the ESX server same error that the port is being blocked.
~ # vemcmd show port
  LTL   VSM Port  Admin Link  State  PC-LTL  SGID  Vem Port  Type
   20     Eth3/4     UP   UP    F/B*    305     3    vmnic3
   49      Veth6     UP   UP    FWD       0     3      vmk3  VXLAN
   50      Veth9     UP   UP    FWD       0        Firewall (06e3...894314ce).eth1
   51      Veth8     UP   UP    FWD       0     3  Firewall (06e3...894314ce).eth0
   52     Veth16     UP   UP    FWD       0        VAN300WTEST1 (...50a) ethernet0
   53     Veth10     UP   UP    FWD       0     3  HTVS274 - Intermidiate.eth0
   54     Veth15     UP   UP    FWD       0        Dummy_Cloud_VM...c565decd).eth1
   55     Veth14     UP   UP    FWD       0        Dummy_Cloud_VM...c565decd).eth0
   56     Veth19     UP   UP    FWD       0        vApp-SMS-DCR-W...c6a) ethernet0
  305        Po2     UP   UP    F/B*      0
* F/B: Port is BLOCKED on some of the vlans.
589
