Bonded T1s
Hi all,
I would like to know how to configure a single T1 DSU/CSU connecting to a single circut but the service provider is provisioning 2 T1/bonded ckts?
Thanks in advance,
sK
Re: Bonded T1s
If you only have one port on your T1 card, you won't be able to use the second circuit. You'll need to either get another card with a single port, or replace your existing card with a dual port card. If you already have that, then you can configure a multilink bundle:
int s0/0
no ip address
encaps ppp
ppp multilink
ppp multilink group 0
int s0/1
no ip address
encaps ppp
ppp multilink
int multilink0
ppp multilink
ip address 5.5.5.5 255.255.255.0 <-provider assigned IP address
HTH,
John
HTH, John *** Please rate all useful posts ***
Re: Bonded T1s
Thanks John. That's was my thinking too; however, the service provider is only bringing one cable(one jack) to premises but stating that the CKT is a bonded T1 (Point To Point). So, that's why I have a single T1 DSU/CSU module in place to plug the single ckt in. Is the service provider misleading me or is there another way of configuring the single T1 to use bonded T1s?
Thanks in advance,
sK
Re: Bonded T1s
Are they bonding them on their end? What you might try is configure one serial interface, and then do a bandwidth speed test to see if you're getting +3Mb.
I don't know of any other way to bond the T1 line because, in my experience, it's usually done at the router end unless the provider is doing something.
HTH,
John
Re: Bonded T1s
I think that bonding is occuring on the service provider's end. Out of curiosty, how would I perform a bw speed test from the router?
sK
Re: Bonded T1s
Not from the router, but from a host behind the router. There are a ton of sites out there that can tell you what your up/down speed is.
John
Re: Bonded T1s
Thanks again John.
sK
Re: Bonded T1s
Tx,
sK
Re: Bonded T1s
Hi John,
Sorry for the middle interupt but it is so interesting.
As you said about bandwidth speed test to see if you're getting +3Mb.
Can you just help me out how we can check the bandwidth speed, is it from router or any other devices we need.
Naidu.
Re: Bonded T1s
The best way to check BW is to go.for a simple FTP test
Re: Bonded T1s
Hi Rajesh,
Thanks for your response.
Could you just tell me clearly and give the proper step by step to check BW.
Note: I need to know how much BW i am getting from Provider.
Naidu.
Re: Bonded T1s
Hi John,
What would the proper way to configure the singel serial interface for a Point-to-Point type of service?
Tx,
sk
Re: Bonded T1s
That depends on the provider. They would provide you an address, and then you'd put it on your serial interface with the proper encapsulation. By default, serial interfaces use hdlc encapsulation. The provider will tell you if it's frame-relay or hdlc.
HTH,
John
Re: Bonded T1s
Thanks John.
I found out that the type of service we are getting is an at&t MIS type of service. So, I think that the ppp would be the encapsultion used in this case, correct?
Tx,
sK
Re: Bonded T1s
Ah. I believe so. They should be able to help you with the settings. We're switching over the MIS also to a 20mb line. :)
John
Re: Bonded T1s
Hi John,
In the BW statement under outbound interface, what should be the BW configured for a bonded 2 T1s?
sK
Re: Bonded T1s
Hi John,
sK
Re: Bonded T1s
If you only have the one connection coming in, you can do 3088 (1544*2). The only this does though is to provide a calculation with certain routing protocols and bandwidth measurements. It won't control speed, so if they're really only pushing 1 T (1.5Mbps), then you won't see 3MB even if you set it on the interface. Does that make sense?
John
Re: Bonded T1s
Yes, it makes sense; however, they are promising 2xT1 (bonded CKTs)but with only a single cable which will be connected to the CSU/DSU! Now, will be receiving 3088 or 1.54Mbps, that will be put to the test once the ckt is up. So, you I will configure the interface with 3088.
Thanks again John,
sK
Re: Bonded T1s
Thanks again John,
sK
Hall of Fame Super Gold
Re: Bonded T1s
No, that does not makes sense, because it is impossible to give a 3mbps service using a single T1 interface that only runs at 1.5 mbps.
And you cannot "configure the interface with 3088".
So, either they will give you a enthernet interface, or two physical T1 interfaces.
Re: Bonded T1s
Agreed. But when the OP said "bonded T1s" that's how this thread got started.
I disagree on your second statement. Yes you can: (It's just for calculations)
interface Serial1/0
bandwidth 3088
no ip address
end
Ethernet possibly. Maybe they'll receive a device that bonds the two at their location and they'll connect to a switch from their router which is highly possible. I think the provider should step in and tell them exactly what needs to be done though. Seems that there's a lot of "in the air" stuff from AT&T.
John
Re: Bonded T1s
Technically is would be 3072, But I'm pretty sure it's managed based on the email from AT&T. He will use the Ethernet port on his router and set the proper IP/Mask and Default GW. Very simple setup. He may have to run the Ethernet cable from the Demarc to connect the circuit into AT&T router if they don't go out there to physically set it up.
Jonathan
Re: Bonded T1s
interface Serial1/0
bandwidth 3088
no ip address
If you do this:
1. the physical behavior or spred of the interface will NOT change.
2. anything based on interface speed, as simple as an smnp graph will be wrong.
So, don't change bandwidth parameter to thing different from reality.
Re: Bonded T1s
So is this csu/dsu being provided and are you useing a Wic-1t or are you using a WIC-T1-DSU? If your using a wic-1t its conceivable that you would be able to get a higher bandwidth than 1.544.
Re: Bonded T1s
Thanks for the response. I didn't know there was a difference btwn the two WICs since T1 data rate is known to provide 1.54Mbps. Are there any docs to show the difference?
Thanks, SK
Re: Bonded T1s
There is no difference. The presence of a internal or external DSU does NOT change the circuit speed of 1544 kpbs, of which 1536 are available to hdlc / ip.
Re: Bonded T1s
Thanks again John,
sK
Re: Bonded T1s
Sounds like it will be a managed service. Meaning they will place an Cisco 1841 router at your location to terminate the circuits and handoff to you on a LAN port. That's what I take from the Single Cable deal. Can you verify if they are providing a router or not to terminate the circuits?
Jonathan
Re: Bonded T1s
Hi Jonathan,
No, this will not be a managed service. We have our own 2851 router with a new T1/CSU-DSU module that I installed last week.
Here is a snapshot of thread of emails btwn me and at&t rep:
To: Me
Correct. The only thing you will have to do, concerning the equipment, is make sure the modem, router, and circuit are connected properly and powered on.
To: at&t rep
Subject: RE: AT&T: Customer Advisory Letter: Ready for Test & Turn up
I am assuming that the bonding of the T1s is done on your end but not on our end, meaning, if there is only one physical ckt (single cable) being provided and we are plugging this single cable into a single T1 DSU/CSU module, we aren't doing any bonding on our end. Would this be accurate?
Thanks in advance,
sK
387
