02-08-2008 12:58 PM - edited 03-05-2019 09:02 PM
I have a config that is too large for nvram. I am running a 3725 router with 12.4 IOS. The boot buffersize command no longer functions in this version. Is there a different command i can use to do the same thing?
Solved! Go to Solution.
02-14-2008 11:37 AM
Use service compress-config will solve the NVRAM size issue and the user is not required to configure the command boot buffersize.
02-14-2008 11:37 AM
02-25-2008 01:33 PM
Thanks! That solved my problem.
