Boot image not found
tgusset
Hello
after upgrading IOS on a 2651XM the router does no longer boot.
After power up or reload it stops in monitor:
Jan 9 10:13:48.244: %SYS-5-RELOAD: Reload requested by vty0 (172.16.31.10). Reload Reason: Reload Command.
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Copyright (c) 2003 by cisco Systems, Inc.
C2600 platform with 262144 Kbytes of main memory
loadprog: bad file magic number: 0x0
open: failed to find and/or load the bootloader: "flash:S00103020002.bin"
loadprog: error - on file open
boot: cannot load "c2600-ipvoice-mz.124-9.T1.bin"
boot: cannot load "flash:"
rommon 1 >
Set shows the correct boot file:
BOOT=c2600-ipvoice-mz.124-9.T1.bin,1;
If I try to boot from monitor it works fine:
rommon 2 > boot flash:c2600-ipvoice-mz.124-9.T1.bin
program load complete, entry point: 0x80008000, size: 0x174a658
The config also contain the correct boot file:
boot-start-marker
boot system flash c2600-ipvoice-mz.124-9.T1.bin
boot-end-marker
The file is on the flash:
RO-3OG-EDV-1#show flash
System flash directory:
File Length Name/status
17 707 ata001818030625
18 24422352 c2600-ipvoice-mz.124-9.T1.bin
19 497 DistinctiveRingList.xml
I don't have any more ideas.
thanks,
Thomas
10 Replies 10
eofelt
I agree with amit.
I was going to post this earlier.
The original post contains several error messages including this:
If the problem were an incorrect config register value that was booting into rommon there would not be an error message like this.
Rick
Rick
Can you try:
boot system flash flash:c2600-ipvoice-mz.124-9.T1.bin
the effect is the same:
RO-3OG-EDV-1(config)#boot system flash flash:c2600-ipvoice-mz.124-9.T1.bin
results in:
boot-start-marker
boot-end-marker
Richard Burts
Thomas
It seems trivial but I would suggest changing the configuration and put a colon between flash and the file name. So
becomes
boot system flash:c2600-ipvoice-mz.124-9.T1.bin
Give it a try and let us know if it helps.
Rick
Rick
Hi Rick
I tried this:
RO-3OG-EDV-1(config)#boot system flash:c2600-ipvoice-mz.124-9.T1.bin
but the config is the same than before:
boot-start-marker
boot-end-marker
Thomas
amit-singh
Level 8
Level 8
Thomas, I think there is some problem with the IOS.May be this IOS is corrupt. I faced the same problem on my 1700 router today and I had to put in a new image on the router. Try tftp a file to the router using if "tftpdnld" option is available in rommon. If not then you have to use "XMODEM" to transfer a new file.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
HTH,
-amit singh
The image is ok, the router works fine - I can boot it with this image from rom monitor and than it boots and works like expected.
amit-singh
Level 8
Level 8
Thomas, what is the config-register setting on your router.Make sure that its is 0x2102.Check it in the rommon and chnage it if its not the same.
-amit singh
ahmednaas
Level 4
Level 4
Why is it trying to load this file before loading the ios image? This looks like a ccme support file.
Here is what I would do:
- erase flash
- copy ios image to flash
- copy ccme support files to flash. These change for each version of ccme.
- reload
