Booting from Flash on Sup720 disk1: in Cat6500
We have just purchased two new Sup720's to replace Sup32's in our Cat6500 chassis. I've loaded a new image onto a Compact Flash card in disk1:.
- I've loaded the image into the Flash card in Slot1 (disk1)
What I can't do is get the Cat6500 to boot from the flash card. Instead it keeps booting from the image on the sup_bootdisk file.
Is it something to do with having to run the install command as stated at the bottom of the following extract or should I delete the sup-bootdisk file.
Extract of code;
Router#dir disk1:
Directory of disk1:/
1 -rwx 81798660 Jan 27 2009 11:24:50 +00:00 s72033-ipservicesk9_wan-mz.122-18.SXF8.bin
509599744 bytes total (427794432 bytes free)
Router#show boot
BOOT variable = disk1:s72033-ipservicesk9_wan-mz.122-18.SXF8.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Router#show ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-VM), Version 12.2(18)SXF12
, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sun 18-Nov-07 07:46 by kellythw
Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR:
Router uptime is 26 minutes
Time since Router switched to active is 26 minutes
System returned to ROM by reload at 11:50:42 UTC Tue Jan 27 2009 (SP by reload)
System image file is "sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF12.bin"
cisco WS-C6509-E (R7000) processor (revision 1.3) with 491520K/32768K bytes of m
emory.
Processor board ID SMG1110N3NP
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
100 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed imag
e. To install please use the "install file" command
Re: Booting from Flash on Sup720 disk1: in Cat6500
From IOS try the following command-
boot system disk1:/s72033-ipservicesk9_wan-mz.122-18.SXF8.bin
save and reload and it should come up with the new image.
Hope that helps.
i think SUP720 have boot statement as sup-bootflash:imagename.
Mahmood
The correct boot string to boot the specific image from your CF.
boot system flash disk1:s72033-ipservicesk9_wan-mz.122-18.SXF8.bin
Also don;t forget to remove, or adjust your existing bootstrings accordingly.
HTH,
Mark
1164
