booting problem in l3 catalyst 4006 switch
I m facing problem in booting the catalyst 4006 switch
1) it has supervisor III engine.
the symptoms are- it is showing blinking red on Status LED
2) It is not giving any output when i m connecting it by console.
1 REPLY
Purple
Re: booting problem in l3 catalyst 4006 switch
Not much to go on , if you are getting no output from the console and you are sure your emulator settings and cable are correct then its time to get the supervisor replaced.
138
