Both HSRP Switches on Active State.
mahesh18
Level 6
Level 6
Hi all,
I have enabled HSRP on 2 Layer 3 switches A and B.
They both connect to different layer 2 switches.
Layer 3 switches  A and B connect directly with each other on gi 1 and 2 ports.
Switch A has standby ip priority config for vlan 10 and 20 as 150 so that it remains active.
This is what i tested.**********************************************************************
when i shutdown the ports gi 1 and 2 then
Both switches A and B become active for vlan 10 and 20.
There  Standby router is unknown undr vlan 10 and 20 for both layer 3 switches.
Need to know why both switches become active for vlan 10 and 20  after i shutdown ports connecting them.?????????
Before shutting down ports Switch A  was active for both vlans 10 and 20.
MAhesh
3 Accepted Solutions
Nandan Mathure
Hi Mahesh,
Since both switches cannot communicate using "Hellos" they start thinking they are the only switches go "Active" . When you allow them to communicate then they can negotiate using priorities in Hellos about who will be "active" or "standby".
THanks,
Nandan Mathure
John Blakley
Mahesh,
In addition to what Nandan said, you'll also need to make sure that you're using the same group number between the 2 switches as well. If they're different, they'll become active for their respective group. Also, make sure that the ports that these switches connect to are trunked and have vlans 10 and 20 allowed on the trunk, and if there's a connection between the 2 L2 switches those will need to be trunked as well and also have 10 and 20 allowed on the trunk.
HTH,
John
HTH, John *** Please rate all useful posts ***
Aileron88
It's worth remembering that for HSRP to work correctly traffic needs to flow between 224.0.0.2, so you will need to take this in to account with any access-lists that are applied.
Adam
6 Replies 6
Nandan Mathure
Hi Mahesh,
THanks,
Nandan Mathure
due to link failure between routers, when  both router hsrp active, is there will traffic flow ?
John Blakley
Mahesh,
HTH,
John
smehrnia
Level 7
Level 7
Hi Mahesh,
you mean you shut down the ports, Leave them shutdown and both get to be "Active", or you shut / no shut, and still u have them both active?
in case of shutting down the ports, the Lower priority node, remains active, the other one though, thinks it has lost the active member and becomes Active for its group.
if you shut/no shut, and both remain active, add this command under respective HSRP group in ur switches, so the lower priority switch takes control immediately when link is back up:
standby 1 preempt   ....   where 1 is the group number
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Hi soroushm,
i mean  when i  shut down the ports connecting layer 2 switches , Leave them shutdown and both get to be "Active",
yes i mean that.
when you say this --
Does this mean that standby switch thinks it has lost the active memeber and then standby becomes active with lower
priority?
Mahesh
Aileron88
Adam
