BPDUGuard errdisable
Dragomir
I connected a Dell Vrtx chassis with a built in L3 switch to a nexus 2000 fex but the port immediately becomes disabled. Any idea?bdpu.jpg
2 Accepted Solutions
try enabling  the spanning-tree bpdufilter feature on the interface.
BPDU Guard, on the FEX 2K is PERMANENTLY enabled by default.  You will not be able to disable it.
On the DELL L3 switch, disable STP portfast and see if this works.
12 Replies 12
Dragomir
So since this is a L3 integrated dell switch. Is it possible to hang this off a FEX or does the FEX only support end devices?  I have bpduguard enabled on this port
this is the config on the port connected to the switch
version 6.1(2)
interface Ethernet101/1/19
  no description
  lacp port-priority 32768
  lacp rate normal
  switchport
  switchport mode access
  no switchport dot1q ethertype
  switchport access vlan 50
  switchport trunk native vlan 1
  switchport trunk allowed vlan 1-4094
  spanning-tree port-priority 128
  spanning-tree cost auto
  spanning-tree link-type auto
  spanning-tree port type edge
  spanning-tree bpduguard enable
  no spanning-tree bpdufilter
  speed auto
  duplex auto
  flowcontrol receive off
  flowcontrol send on
  link debounce time 100
  no beacon
  delay 1
  snmp trap link-status
  logging event port link-status default
  logging event port trunk-status default
  no ip dhcp snooping trust
  no ip arp inspection trust
  no ip verify source dhcp-snooping-vlan
  no shutdown
Tony,
Yes usually Fex are to be used only to connect the servers not to any third party switches.
One way to do it is configure the switch not to send BPDU, the HIF of the FEX will be able to connect to a switch. However, you can have a protential STP loop in your networ. Hense, this is not recommended.
From 5.2.1, by default the host interfaces are Layer 3. Hence you can connect it to switch if you want to keep it just Layer 3.
But if you want to keep the port as layer 2, then as Jeye mentioned, bpduguard is enabled by default.
Now when you connect a switch to FEX, it will send out a BPDU and hence the FEX port will get err-disabled.
If you want to connect a switch to those port then you need to enable bpdu filter on the switch interface which connects to FEX. This will prevent any BPDU going from switch to FEX and hence it will work out for you.
Always care should be taken when you enable bpdu filter since that will not help you if you have spanning-tree loop since you are not passing BPDUs.
For more reference:
http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus2000/sw/configuration/guide/rel_521/Configuring_the_Cisco_Nexus_2000_Series_Fabric_Extender_rel_5_2_chapter1.html#con_1046083
Inayath
        ************PLEASE RATE IF THIS INFO IS HELPFULL****************
Yes that enabled the port. But will it cause any loops? does enabling the bpdufilter on this port cause any problems?
I actually have 4 ports on this switch that I need to connect to the FEX. Would enabling bpdufilter on all 4 ports cause problems or do I need to setup some etherchannel?
thanks
ok I disabled STP on the L3 Dell and the interface came up.
on the fex I see this
sh spanning-tree interface ethernet 101/1/19 detail
Port 4196 (Ethernet101/1/19) of VLAN0050 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.4196
   Designated root has priority 16434, address d867.d907.ffc1
   Designated bridge has priority 16434, address d867.d907.ffc1
   Designated port id is 128.4196, designated path cost 0
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   The port type is edge
   Link type is point-to-point by default
   Bpdu guard is enabled
   Bpdu filter is enabled by default
   BPDU: sent 11, received 0
BPDUs are being sent. Is that going to cause a loop?
if I added another link and disabled STP portfast on it, would that be a problem?
No it won't because STP will take the full 55-second cycle.
looks like this caused a problem. with 2 links on the switch attached to the fex and both enabled caused a loop. why would one be ok and 2 not?
why would 2 switch links connected to the fex cause a loop? both ports were spantree disabled
If both ports have STP disabled, it will not cause a loop because STP will do it's job.
stp was disabled only on the dell switch. not on the fex. i initially have only stp disabled on one of the dell switch ports and there was no loop. After i disbaled stp for the second link and did a shut and no shut on the cisco port side, everything came to a halt
