02-14-2008 07:14 AM - edited 03-05-2019 09:09 PM
Got a brand new 2851 and it appears it has a problem when I try to do a write mem I get the following . any way around this or is time to RMA .
*Feb 14 15:13:37.543: %SYS-5-CONFIG_I: Configured from console by console
*Feb 14 15:13:39.463: NV: Invalid Pointer value(45911384) in private configuration structure
*Feb 14 15:13:39.503: NV: Invalid Pointer value(45911384) in private configuration structure
*Feb 14 15:13:39.503: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometry of nvram
Solved! Go to Solution.
02-14-2008 07:38 AM
Hi Glen,
Had the same problem with a 3845 the other week.
Try the following
erase /all nvram:
This will erase the NVRAM, Re-Initialise the geometry and reset the pointer unlike the "erase nvram" command.
Hope this helps, if so please rate.
Dave
02-14-2008 07:38 AM
Hi Glen,
Try the following
erase /all nvram:
Dave
02-14-2008 07:42 AM
Dave you are the man , that fixed it . Thats what is great about this forum . Saved me the hassle of RMAing the device . Got to keep that one in the back of mind .
