Bridge Group replacement
I am moving from a 7500 router to a 6500 platform.
I use bridge groups with the 7500 series, as I see bridge groups are not availible in the 6500 platform.
What can I use as a replacement?
Here is one of my applications:
Ethernet interface bridged to a ATM sub interface.
dan-
Re: Bridge Group replacement
Just want to clarify,
What command can I use on the 6500 platform that will act simular to a bridge-group?
Purple
Pretty sure bridging is available if you are running a correct feature set . We use bridging on a Sup 720 , think we have enterprise services feature set .
Its in the feature set I have, but I am unable to find a way to add an atm sub interface to a bridge-group.
Hall of Fame Super Silver
Hello Dan,
while I was looking for another thread I've found the following config example:
Router(config)# interface serial3/0/0
Router(config-if)# no ip address
Router(config_if)# encapsulation ppp
Router(config-if)# bridge-domain 100 dot1q
Router(config-if)# service-policy output vlan-inner-100
Router(config-if)# shutdown
Router(config-if)# no shutdown
Router(config-if)# end
bridge-domain
Enables RFC 1483 ATM bridging or RFC 1490 Frame Relay bridging to map a bridged virtual LAN (VLAN) to an ATM permanent virtual circuit (PVC) or Frame Relay data-link connection identifier (DLCI).
http://www.cisco.com/en/US/docs/ios/bridging/command/reference/br_a1.html#wp1011949
I would give it a try
Hope to help
Giuseppe
I will give it a try, Thanks!
Does anyone know what the difference between these is?
bridge-domain 40 dot1q
and
bridge-domain 40 access
Well, I figured that out.
I will test and hopefully it works out.
Thanks!
Problem already:
%bridge-domain rejected: unable to allocate port
Is there a limit to how many interfaces can belong to a bridge-domain?
Hello Dan,
as I wrote I haven't tried this already.
I think it is time to look at the details of your C7600 chassis.
Have you got an ATM PA on a Flewwan or it an ATM SPA on a SIP linecard
RFCs 1483 and 2684 ATM Bridging is reported on enhanced Flexwan datasheet
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet09186a00801df1d9.html#wp46582
SIP400 datasheet doesn't report the same feature
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9e6_ps708_Products_Data_Sheet.html
So I'm afraid it can be unsupported depending on your hardware.
Hope to help
Giuseppe
I have a 6500 with ATM PA on FlexWAN.
I was able to use bridge-domains on several interfaces, after adding several I started getting %bridge-domain rejected: unable to allocate port
Maybe I need to look at a different option altogether. Not sure what though.
402
