Bridge IDs
shane.kearney
Which of the following Bridge IDs would win the election.
32768:0200.1111.1111
32768:0200.2222.2222
200:0200.1111.1111
0200:0200.2222.2222
40,000:0200.1111.1111
7 Replies 7
shane.kearney
this question is from the icnd 2 book but i think the answer is wrong!!!
Francois Tallet
Level 7
Level 7
Assuming there is no trick like 0200 being octal vs 200 decimal;-) I would vote for 200:0200.1111.1111
Francois
Am I wrong to think the bridge IDs can only be in multiples of 4096?
by the way you are correct and i was wrong
Hello Shane,
bridge IDs can only be in multiples of 4096 if using extended system-id otherwise they can be any value between 0 and 65535.
Hope to help
Giuseppe
Last Question,
How do you know if the extended System is used or not?
Thanks for all the help.
Hello Shane,
two ways
a) from configuration
b) do sh spanning-tree vlan 1
and
sh spanning-tree vlan x
if using extended id:
bridge priority in vlan x will be:
base pri + x
if not using extended id
bridge pri in vlan x = bridge pri in vlan 1
but MAC address differ
(the extended id feature is also called mac address reduction for this reason)
Hope to help
Giuseppe
Note that even with extended sysid, the priority will end up within the range 0-65535. Sure, you can only configure the higher 4 bits of the priority (by increment of 4096 indeed), but as you eventually add the vlan number to this configured priority, you end up with a figure that utilize the whole 64k range.
Francois
