Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Bridging ethernet on 1721 router
Hi folks!
I have a 1721 with an ethernet wic. I want to bridge the fastethernet0 and ethernet0.
When I set up the bridge-group etc - I cant get frames to pass in either direction.
I need this to test vpn devices across transparent bridging and throttle the i/fs down - I can't use routing - is it possible?
Any help or tips would be greatly appreciated!
First, can you bridge the ethernet0 to fastethernet0 on the 1721.
Second, if so - config would be great!
1 ACCEPTED SOLUTION
Re: Bridging ethernet on 1721 router
You need to configure protocol and bridge routing parameters.
Sample config:
bridge 1 protocol ieee
bridge irb
interface fastethernet 1/0
bridge-group 1
exit
int ethernet 0/0
bridge-group 1
exit
This should enable bridging between the interfaces.
http://www.cisco.com/en/US/docs/ios/bridging/configuration/guide/br_transprn
t_brdg_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1003018
Hope this helps.
NT
Graham, whats the current bridge related configuration you have put on ?
Sample config:
bridge irb
bridge-group 1
exit
int ethernet 0/0
bridge-group 1
exit
Hope this helps.
NT
Hi Rob, Nagaraja
Many thanks for your replies.
Nagaraja, I remember messing with the protocol and routing commands but maybe I didn't try exactly as you have shown or both together.
I'll try again tonight (It's my Lab router).
I was starting to think I might need to get a 2960 switch and use QOS!
Again, thanks for taking the trouble to reply.
Graham
Hello Nagaraja
Thanks - I must have missed something but when I tried your config it all worked great.
I  appreciate your help - thanks!
regards Graham
373
