Community Member
bridging serial link to ethernet
Hi all, If I have a leased line connection presented on a 2 meg serial connection on my router, would it be possible to bridge between them, would I have to configure the router as a bridge either end, is this possible ?
cheers
Carl
Community Member
Re: bridging serial link to ethernet
can anyone help on this ?
Silver
You can set up your router as a bridge. enable no ip routing on your router. The serial link set for bridge group 1 and add the same command to the ethernet interface. Add bridge group 1 protocol ieee (global command). This will enable the router to be a bridge and will bridge the traffic from the ethernet to the serial link....Good Luck...
273
