06-09-2014 11:47 PM - edited 03-07-2019 07:40 PM
06-10-2014 11:37 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, I'm wondering whether a helper cannot forward fragments.
If not, if you enable jumbo support on the 3750, you might be able to send larger diagrams, but perhaps not larger than MTU.
06-11-2014 04:55 PM
Thanks Joseph,
Wireshark informs me that datagrams less than around 5912 bytes are fragmented and reassembled between VLANs successfully by the helper.
Jumbo frames are enabled on the 3750's with an MTU of 1500. I'll up this to 9000 to see if it makes a difference.
JC
