Community Member
broadcast problem in LAN
hi,
i am getting unicast ie to my machine only , but when i am trying to do
broadcast,none of pc in network getting broadcast.
my pc ip is 10.3.128.201
subnet mask 255.255.240.0
i have given bcast address in my code as
10.3.128.255
is there any problem in my bcast address?/?
please help...
Hall of Fame Super Blue
Re: broadcast problem in LAN
Your broadcast address should be
10.3.143.255
Your network is 10.3.128.0 255.255.240.0 which means you have 16 class C subnets
10.3.128.0 -> 10.3.143.0
Jon
Community Member
thnks a lot Jon
Community Member
hi
i have given bcast ip as 10.3.143.255
now also i am not getting broadcast.
is there any problem with UDP port?/?
Ajay
Ajay
What exactly are you trying to do and how do you know that you are not receiving any broadcasts ?
Jon
Community Member
i have a braodcast process which is receiving messeges from some source.Now i have to send these messeges to all front end guys.when i do unicast, i am able to get messeges.
but when i give broadcast ip, no one (including my self) is getting messeges.
my application is running on AIX.
Ajay
Hall of Fame Super Gold
Ajay
I am still a bit confused about your topology and about your problem. Can you clarify whether the device that is issuing the broadcast is within the subnet and sending broadcast to the subnet or if it is outside the subnet and sending the broadcast.
If the source of the broadcast is outside the subnet then I believe that I understand the problem and can suggest a solution. First lets be clear about some terminology. If a packet is sent from outside the subnet to the subnet broadcast address then this is termed as a directed broadcast. And directed broadcast is not enabled by default in the IOS. There is an interface configuration command ip directed-broadcast. If you configure that command on the interface then it will enable forwarding of directed broadcasts from outside onto the interface and will reach all the devices within the subnet.
Rick
563
