11-06-2013 06:50 PM - edited 03-07-2019 04:28 PM
Qus) Ip address can be used to specify a broadcast and map to hardware broadcast if available.by conversion
broadcast address has hosted with all bits.
(1) 0
(2) 1
(3) Both (1) and (2)
(4) None of these
What will be the answer of this question in above options ?
11-06-2013 07:53 PM
answer is (2) 1
11-06-2013 09:54 PM
Only in the host part,all the bits will be 1.
For,192.168.1.0/24 network
subnet mask will be 255.255.255.0
Broadcast address will be 192.168.1.255
Now, we shell convert the broadcast address into binary
192 in Binary- 11100000
168 in Binary- 10101000
1 in Binary- 00000001
255 in binary- 11111111
So only in the host part all bits will be 1.
Check this
https://www.countryipblocks.net/identifying-the-network-and-broadcast-address-of-a-subnet
Gurudath
11-07-2013 02:19 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
That's correct for an IP network broadcast (or directed broadcast). A full IP broadcast all bits are 1.
On such a network, you might try:
ping 192.168.1.255
or
ping 255.255.255.255
11-06-2013 10:08 PM
Sorry to say this. I'm on the way to CCNA.
I didn't understood the question at all. Can someone make it a bit clear ?
Chandu
11-07-2013 06:38 AM
The question confused the **** out of me, im glad the actual CCNA questions are not written like this
