Community Member
Broadcast
Is it possible to send broadcast from one vlan to another?
Community Member
Re: Broadcast
vlan is a logical broadcastDomain and it's function like a physical L2 switch.not possible to send broadcast from one vlan to another vlan
Re: Broadcast
Hello Fahad,
Are you referring to L2 or L3 broadcast. There are some features like "Wake on Lan" that uses broadcast and you can configure this traffic to go from one vlan to another but it has has to go through a SVI(L3)interface. Refer the below URL for details:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a008084b55c.shtml
Arul
*Pls rate if it helps*
Community Member
Re: Broadcast
Thanks.. It was of great help..
125
