08-24-2009 11:56 AM - edited 03-06-2019 07:23 AM
Hello Experts,
My 7600 router seems to be hitting bug CSCec40868.
Its running version 12.2(33)SRC3 is listed on the affected ones, and we upgraded it to this
c7600rsp72043-adventerprisek9-mz.122-33.SRC4.bin
It didn't help, the issue is still the same.
Attahced is the sh tech and iftable from the device.
Any ideas? Thnx a lot
Solved! Go to Solution.
08-24-2009 11:26 PM
May be some regression of something else.
I remember mentioning you this bug, but as you said you run a newer version. This may be a new defect and would need further troubleshooting.
On this one, it seems we need a TAC case.
08-24-2009 12:34 PM
Maybe you did not hit this bug.
In Affected version, there is a notes as following:
"12.2(33)SRC3 A Cisco employee (rbibian) has confirmed CSCec40868 does not affect this version."
08-24-2009 12:53 PM
I see. Is there any other bug we may be hitting? I've searched for bugs, and could not find any that would apply.
We have rebooted the router, with no changes.
08-24-2009 01:08 PM
Which interface you did not see in ifTable?
08-24-2009 01:14 PM
These are the interfaces:
interface Serial2/1/0
interface Serial2/1/1
interface Serial2/1/2
interface Serial2/1/3
Thank you
08-24-2009 11:26 PM
08-25-2009 07:41 AM
Ok Lucien, I'll open a TAC now.
Thanks a lot.
