11-10-2008 08:34 AM - last edited on 03-25-2019 04:03 PM by ciscomoderator
Where can I found a doc or link that list ALL (recents and olds) bugs from an IOS (12.0(5.2)XU)?
In the release note of this IOS don't says anything about my problem (the doc's date if July 20, 2000)... The switch has a proble like a memory leak.
Solved! Go to Solution.
11-10-2008 09:23 AM
Danilo
You can use keywords in your search but you may well miss something if you don't get the right keywords.
Also you can then narrow it down to specific technologies.
But sometimes when you don't have this sort of information you just have to go through each one. It's painful i know as i have had to do it a number of times.
Jon
11-10-2008 08:42 AM
You can use the Cisco Bug Toolkit -
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
you will need to be a Cisco registered user with a Cisco service contract.
Jon
11-10-2008 09:15 AM
I've tried Jon, but my search show me a lot of bugs (961). I'm trying to filter the search.
Do you have suggestions?
11-10-2008 09:23 AM
deleted
11-10-2008 09:23 AM
Danilo
Jon
