03-04-2008 07:22 AM - edited 03-05-2019 09:32 PM
I remember in catOS you could make changes to multiple ports with a single command. for e.g.
set vlan 99 2/1-6 etc.
So using the above as an example how would i do this in IOS?
Thanks a bunch.
Solved! Go to Solution.
03-04-2008 07:35 AM
interface range gigabitethernet 1/1 - 48
The spaces between the dash and numbers is necessary.
If so, pelase rate this post.
Victor
03-04-2008 07:35 AM
Victor
03-04-2008 08:18 AM
Also:
-create a macro
Define interface-range int_range g1/1 - 48
-use the macro you created
Interface range macro int_range
Int_range represents a word describing the macro you created. The macro is saved in the run/start config.
03-04-2008 08:28 AM
Thaks guys. I am assuming the macro is set per switch, would that be correct?
