02-15-2007 09:45 AM - edited 03-05-2019 02:23 PM
HI EXPERTS!
We can make a bandle of etherchanels(4 links)the first 3 are 1 gig each one;but the 4th 1 is 300M but the 300M is Runing on gig interface;can we form a bundle of etherchanels(4 links) here ow what?any help here!!!
10xs
02-15-2007 10:12 AM
Hi Ali
Do you mean can you put all 4 links into one Etherchannel bundle ?
As far as i can see yes you should be able to. An etherchannel will form if all the ports have the same speed capabilities so if they are all gigabit capable i would think it would work.
You might not want to do this though as etherchannel load-balances across its links. 3 of your links are gigabit but the other one is 300Mbps.
How are you restricting the traffic on the 4th link to be 300Mbps ?
Jon
02-16-2007 07:00 AM
HI Jon!
1)Do you mean can you put all 4 links into one Etherchannel bundle ?
yes; the 4 link in Etherchannel bundle ;but i have 1 of this bandle 300M but runing on gig interface,because as you know:the speed is 10m;100m,1000g..can we form bandle of Etherchannel?
10xs
02-16-2007 07:05 AM
Hi Ali
Yes the etherchannel should form as all the switch sees are 4 gigabit connections. As long as you have checked the guidelines and restrictions and all the ports have the same capabilities i see no reason why it won't work.
Jon
02-16-2007 07:27 AM
HI Jon!
HI Jon!10xs for ur reply!!!
ALI
02-18-2007 12:55 AM
HI Sayeed,
I didnt get what do u mean by 300M.can u explain.If u want to have etherchannel u need to have all the ports in the same switch and they should have same configurations.
Mahmood
02-18-2007 01:14 AM
HI Mahmoud!
300M it is a wirless Link terminated at GIG Interface;as u know the speed its 10;100;1000.
any comments
