BVI interfaces 3750 Switches
BVI's interfaces are not longer used in the 3750 Platform ?
Re: BVI interfaces 3750 Switches
No, SVI interfaces are now used (Switched Virtual Interfaces). You now create the VLAN at Layer-2 and then add the equivalent SVI interface -
vlan 10
name VLAN-10
vlan 20
name VLAN-20
interface Vlan10
description VLAN-10 SVI
ip address 10.1.1.1 255.255.255.0
interface Vlan20
description VLAN-20 SVI
ip address 10.2.1.1 255.255.255.0
You can also just create the VLAN at Layer-2 and not perform inter-vlan routing on the 3750. I think the older 2948G-L3 and 4908G-L3 switches were the last Catalysts to require BVI's.
Andy
Thanks Andy.
How do you configure the SVI interface ?
Blue
He just showed you:
interface vlan 10
etc...etc...etc
As I posted - you treat it like any other interface? Once the Layer-2 VLAN exists you just add the SVI with the command 'interface Vlan X' where 'X' is the VLAN number, by default it will be shutdown but a 'no shut' will bring it up. To put access ports in the vlan just make sure they are configured as access ports (switchport mode access) and they are in the right vlan (switchport access vlan X).
Andy
769
