C1841 fa0/0 up when unplug LAN cable
When I unplug LAN cable from interface fa0/0 why interface still up but protocol down ?
It is default ? or we can set ?
Thank you in advance.
  • LAN Switching and Routing
2 ACCEPTED SOLUTIONS
Green
Re: C1841 fa0/0 up when unplug LAN cable
If you have keepalives disabled, then the link will stay up.
Check your config, under that interface, for a "no keepalive" statement
Also make sure you are looking at the right interface ....
Good Luck
Scott
Hall of Fame Super Silver
teerapon
It is the default behavior of IOS routers such as the 1841 that if the FastEthernet interface is not plugged into some device then the interface will show as interface up and line protocol is down.
Rick
Green
Good Luck
Scott
Thank you Scott.
So, If I used "no keepalive" command under int fa0/0, interface and protocol will up both but I did not plug LAN cable into that interface.
I also check with another new router C1841. After completed boot and no shutdown the fastEthernet interface. FastEthernet interface is up without LAN cable connected.
It may be default of router? and How to make it down when we did not plug the LAN cable into interface ?
Environment
C1841
IOS c1841-ipbasek9-mz.124-23.bin
Thank you.
teerapon
Rick
227
