Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
C2950-24G NIC compatability
Is there any known compatability issue/problem on the Cat2950G-24-EI  with an onboard SUN NIC card  V890, QuadGigaswift PCI-X R Ethernet (QGE-X) OS version: Solaries 10.
This card can not communicate at 100MB full duplex. it defaults to 100/Half duplex.
kgabo
Everyone's tags (1)
Hall of Fame Super Blue
Re: C2950-24G NIC compatability
kgabo
kgabo
How are the port and NIC configured ie.
either configure both for auto-negotiation or configure both for 100 full duplex but you can't configure one for 100 full and leave the other to auto-negotiate.
Jon
kgabo
Hi Kgabo,
There is no issue with port of 2960 and NIC as suggested configure either in auto/aoto or hardcode maunal setting at both ends and share the results.
Ganesh.H
Purple
Sounds like the sun nic was hardcoded to 100/full which would then put
the switch in 100/half  if it set as auto/auto  which is a normal state .
Either hardcode the switchport to 100/full or set the sun nic to auto/auto .
355
