C2955 Console Authorization Failed
Ross Rehart
I have a client that has a WS-C2955T-12 switch he cannot access. When plugging into the console port, with known good console cable and settings in SecureCRT, I get an "% Authorization Failed". I hit enter and it gets the same error. The switch never gives me a chance to login. Can someone help either (a) with a reset to factory default w/o access or (b) password recovery on a WS-C2955T-12? Thanks in advance.
Yea - I looked at that. There is no "Mode" button on the 2955.
AAA might have been misconfigured in this switch.
If there is no Mode button then, password recovery should be similar to a router:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_19_ea1/configuration/guide/swtrbl.html#wp1177043
I had similar problem on a Cisco WS-C2940-8TF-S.
This whas the config before (obviously 123456 is just to cover private informations):
hostname 123456
enable secret level 15 0 123456
enable secret level 5 0 123456
username 123456A privilege 15 secret 0 123456
username 123456B privilege 15 secret 0 123456
username 123456C privilege 5 secret 0 123456
aaa new-model
aaa authentication login defaut local
aaa authorization exec default local
line con 0
line vty 0 4
exec-timeout 60 0
transport input ssh
line vty 5 15
exec-timeout 60 0
transport input ssh
I added these lines to solve it.
     conf terminal
     aaa authorization exec Console none
     line con 0
     ^Z
Alex
