C2960 ilpower-3-controller_port_err: tstart error detected, no network cables connected
ctinsley01
I have a new C2960 that is reporting the follwing errors in the log when I power it up.  I have put a config on it but it is not connected to any devices except the console cable to my serial port.
ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/11: Power Controller reports power Tstart error detected
LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to up
SPANTREE-2-BLOCK_BPDUGUARD: Received BPDU on port Fa0/11 with BPDU Guard enabled. Disabling port.
PM-4-ERR_DISABLE: bpduguard error detected on Fa0/11, putting Fa0/11 in err-disable state
LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed state to down
LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to down
Any ideas would be greatly appreciated!
Chris
10 Replies 10
Ivan Shirshin
Hello Chris,
The error message means that there is some power being reflected back, and instead of damaging the components in the switch, the power is disabled. This could be caused by a short in the cable, the end device somehow looping the voltage back, port damage or bug causing false diagnostic failures.
Since you mentioned the cables are not connected, the problem has to be local to the switch.
Could you advise on what is the current IOS version the switch is running ("show version")? And do you see such errors with fa0/11 only?
You could try the following commands to flip the PoE settings in case it is some kind of a bug:
conf t
   int fa 0/11
     power inline never
     power inline auto
end
conf t
   int fa 0/11
     power inline port 2x-mode
     shut
     no shut
end
If that does not help and nothing is connected to fa0/11, I believe you have this port damaged.
Kind Regards,
Ivan
Kind Regards,
Ivan
smehrnia
Level 7
Level 7
I could find a bit of info on Cisco.com about this kind of errors (I know your port is not connected at all, but internaly they are all connected and powerd with the controller):
This is the severity 3 Cisco IOS configuration caveat:
CSCed09484
When a type 1 Token Ring patch cable is connected to a PoE port, these syslog messages appear every 10 seconds:
00:01:06: %ILPOWER-7-DETECT: Interface Fa1/0/1: Power Device detected: Cisco PD
00:01:06: %ILPOWER-5-POWER_GRANTED: Interface Fa1/0/1: Power granted
00:01:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,
Interface Fa1/0/1: Power Controller reports power Tstart error detected
There is no workaround. However, when a valid link partner is connected to the PoE port, it operates normally and without user intervention.
>> try changing or updating your IOS ver.
plz Rate if it helped.
Soroush
Hope it Helps!
Soroush.
Thank you for the feedback!  Here is the IOS info:
C2960 Software (C2960-LANBASEK9-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Also, this error only occurs on fa0/11.
Chris
Try updating to Version 12.2(55)SE5.
plz Rate if it help.
Soroush.
Hope it Helps!
Soroush.
Hi Chris,
You are welcome :-)
That IOS version already has the fix for most inline power bugs, such as CSCed09484 (that Soroush mentioned) or CSCeb24148 (switch exhibits %ILPOWER-3-CONTROLLER_ERR: message).
Did you try the commands I suggested above and, if yes, did it have any effect?
Also, please visually check the port to make sure there is nothing in it that would cause a short and make sure to remove switch statics.
Kind Regards,
Ivan
Kind Regards,
Ivan
Ivan,
I ran this:
conf t
   int fa 0/11
     power inline never
     power inline auto
Then, shut, no shut and received the ilpower error and subsequent bpdu, err-disable message.
I tried to run
power inline port 2x-mode but that command is not available.  Here are my options:
power inline ?
  auto         Automatically detect and power inline devices
  consumption  Configure the inline device consumption
  never        Never apply inline power
  police       Police the power drawn on the port
  static       High priority inline power interface
Chris
Hi Chris,
This command was introduced in 12.2(55)SE3 to provide workaround for 3rd party devices.
In the PoE controllers, there are three separate current thresholds that are used for different purposes.  These are I(cut), I(limit), and I(short). I(cut) is used as the threshold at which power is removed from the port if the PD draws more power than allocated. (ex. 15.4W).
With the 2x power mode command we increase the I(limit) to 2x time. This means that we can increase the threshold for the voltage fold-back mechanism, which in some cases causes the switch to not power the 3rd party devices, without increasing the threshold at which power is removed from the port.
But it was like additional check and I don't think it is related,  I suggest you to replace the switch if warranty is still active. All of the bugs for similar problems are caused by compatibility with connected devices, not by empty ports.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hmmm ... Sorry, but won't agree that this has got something to do with IOS.  Not yet, by the way.
Can I ask you a favour?  Can we do a TDR test of the cable?
If you are agreeable then can I ask if you MOVE the cable from FastEthernet0/11 to any of the two available GigabitEthernet ports?  I'll explain shortly.
When you have done so, you need to do some preparation.  Here are the steps:
1.  Configure the GigabitEthernet port.  Let's presume that you are using GigabitEthernet 0/1.  The commands are:
conf t
interface Gig 0/1
media rj
end
2.  Run the TDR command and show the results.  The commands are:
  • Command:  test cable tdr interface Gig 0/1;
  • Wait for approximately 5 to 7 seconds;
  • Command:  sh cable tdr interface Gig 0/1;  and
  • Please post the output.
2.  Undo the settings in #1:
conf t
interface Gig 0/1
media auto
end
The main reason why I would like the test to run on a GigabitEthernet interface is because TDR test on a FastEthernet interface will test only the first two pairs.  If you have PoE and/or GigabitEthernet problems you want to test the third and fourth pair, respectively.
Hope this helps and I await the test results.
Hey Leo...
he said there is no CABLE attached to the chasis except for the Console...
Hope it Helps!
Soroush.
Hey Leo...
Hmmm ... Interesting.
Thanks for the heads-up.  I missed reading that bit.
Hey Chris,
Can you post the output to the command "sh post" please?  And if there's no cable attached to FastEthernet 0/11 can you run the following commands in enable mode:
1.  test cable tdr interface f0/11;
2.  Wait for approximately 5 to 7 seconds;
3.  sh cable tdr interface f0/11; and
4.  Please post the output.
