05-06-2010 09:28 PM - edited 03-06-2019 10:58 AM
Hi All.
Which version of image on c2960 switch support snmpV3 and Transport output ssh commands?
Currently we are running c2960-lanbase-mz.122-35.SE5.bin.
Need urgent help...
Amar
05-06-2010 10:34 PM
Using the Cisco Feature Navigator, you can download 12.2(53)SE1 with the CAT2960 platform with LAN BASE that supports both SSH and SNMPv3.
c2960-lanbasek9-mz.122-53.SE1.bin
05-06-2010 10:58 PM
Hi Neal,
I am Amar colleague, His query is if transport output ssh is supported on any of c2960-48-ttl switch?
Regatrds
Madhu
05-06-2010 10:35 PM
You can used mentioned flash for 2960 and try ("flash:c2960-lanbasek9-mz.122-52.SE.bin")
Jyoti
05-06-2010 10:53 PM
Hi All.
Need urgent help...
Amar
Hi Amar,
Even your current ios supports snmpv3 and ssh
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
05-06-2010 11:00 PM
Hi ganesh
I am Amar Colleague, We tried, Transport output SSH is not supported on c2960-lanbase-mz.122-35.SE5.bin.
Regrads
Amar
05-06-2010 11:07 PM
Hi ganesh
Regrads
Amar
Amar,
Can you try tansport output all, is it working for ssh or not and snmp v3 should work with this image.
Ganesh.H
05-07-2010 12:19 AM
To enable transport out ssh, ensure you are in config mode using "line vty 0 4" and then type "transport input ssh" and "transport output ssh" . To enable snmp on the c2960, you need to be in config mode.
Enabling SNMPv1/v2c on Cisco IOS devices:
Enabling SNMPv3 on Cisco IOS devices:
1. enable
2. configure terminal
3. snmp-server group [groupname {v1 | v2c | v3 [auth | noauth | priv]}] [read readview] [write writeview] [notify notifyview] [access access-list]
4. exit
5. show snmp group
This is for 12.4 but the cli syntax is the same:
05-07-2010 04:45 AM
His version may support it but his version is not a crypto code version so it will not work . Imagename must have a K9 in it.
