Community Member
C2960 image support for SNMPv3 and transport output ssh
Hi All.
Which version of image on c2960 switch support snmpV3 and Transport output ssh commands?
Currently we are running c2960-lanbase-mz.122-35.SE5.bin.
Need urgent help...
Amar
Re: C2960 image support for SNMPv3 and transport output ssh
Using the Cisco Feature Navigator, you can download 12.2(53)SE1 with the CAT2960 platform with LAN BASE that supports both SSH and SNMPv3.
http://www.cisco.com/cgi-bin/Software/SWSearch/SWSearch_results.cgi/SWSearch.txt?isChild=false&file_delimiter=contains&search=Search&searchPhrase=c2960-lanbasek9-mz.122-53.SE1.bin
Community Member
Hi Neal,
I am Amar colleague, His query is if transport output ssh is supported on any of c2960-48-ttl switch?
Regatrds
Madhu
Community Member
You can used mentioned flash for 2960 and try ("flash:c2960-lanbasek9-mz.122-52.SE.bin")
Jyoti
Hi All.
Need urgent help...
Amar
Hi Amar,
Even your current ios supports snmpv3 and ssh
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Community Member
Hi ganesh
I am Amar Colleague, We tried, Transport output SSH is not supported on c2960-lanbase-mz.122-35.SE5.bin.
Regrads
Amar
Hi ganesh
Regrads
Amar
Amar,
Can you try tansport output all, is it working for ssh or not and snmp v3 should work with this image.
Ganesh.H
To enable transport out ssh, ensure you are in config mode using "line vty 0 4" and then type "transport input ssh" and "transport output ssh" . To enable snmp on the c2960, you need to be in config mode.
Enabling SNMPv1/v2c on Cisco IOS devices:
To enable SNMPv1/v2c on Cisco IOS devices, follow these steps:
snmp-server community ro
Enabling SNMPv3 on Cisco IOS devices:
1. enable
2. configure terminal
3. snmp-server group [groupname {v1 | v2c | v3 [auth | noauth | priv]}] [read readview] [write writeview] [notify notifyview] [access access-list]
4. exit
5. show snmp group
This is for 12.4 but the cli syntax is the same:
http://www.cisco.com/en/US/partner/docs/ios/netmgmt/configuration/guide/nm_cfg_snmp_sup_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1201017
Purple
  His version may support it but his version is not a crypto code version so it will not work .  Imagename must have a K9 in it.
1367
