C2960 is down
hi,
I entered "erase start" then "reload". after that syst led started to flashing(green) I have been waiting for 15 min but it is still flashing and it does not work. I have unpluged and pluged the power cable, but everything is still same, could anyone tell me how to solve the problem?
Re: C2960 is down
Hi Serdar,
It seems as hardware problem, make sure able the power which is using by ups.
Naidu
Re: C2960 is down
Hi Naidu,
Thanks for ur interest. "erase start" command deleted IOS of the C2960. I have downloaded IOS to the switch, everything is ok now. Thank you.
Serdar
113
