Community Member
C3500XL Switch
When in config mode # and enter vtp ? I get file Configue IFS filesystem for vtp. I do not get the sub-commands for vtp (domain, mode, filesystem, etc)
Re: C3500XL Switch
Henry,
The commands for configuring VTP on the 3550XL switches are slightly different than newer switches. You will want to use either command in privileged EXEC mode.
vtp server
vtp transparent
vtp client
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_xu/scg/kivlan.html#wp1035247
HTH,
Mark
Purple
Re: C3500XL Switch
I believe those are so old that that is all handled in the vlan database not in global config.
At the command prompt , not config mode enter\
vlan database, enter
your vtp options are in there.
629
