Community Member
C3560-48PSS reset to factory default
i bought a C356048PSS two years ago and has been save config again last week, yesterday after power down the config back to factory default, now the switch up again.
Is it problem about flash or NVRAM,
how to check the switch NVRAM/flash due to any error?
System restarted at 16:38:55 UTC Thu Jul 17 2008
IOS 122-25.SEE2
Lian
Gold
Re: C3560-48PSS reset to factory default
check the output of show version. make sure config register is 0x2102 and not 0x2142.
if it's 2102, let us know and we'll have to consider something else as the problem.
Community Member
I 've checked all my cisco switch config is
Configuration register is 0xF is this correct?
Any thing else cause the reset to the factory default.
Lian
1087
