05-28-2010 05:51 PM - edited 03-06-2019 11:20 AM
Hi:
I just triying to setup a dhcp server in my catalyst 3560 switch for a nortel ip phones. I show you mmy configuration:
VOICE VLAN: 3
DATA VLAN: 1
S1:10.2.110.200
port:4100
Nortel IP Phones: IP 2002 (Firmware Version 0604D9H) & IP 1110 (Firmware Version 0623C7)
Switch Configuration:
aaa new-model
aaa session-id common
ip subnet-zero
ip routing
ip dhcp pool datos
network 10.2.100.0 255.255.255.0
default-router 10.2.100.1
lease 0 2
ip dhcp pool voice
network 10.2.110.0 255.255.255.0
default-router 10.2.110.200
option 191 ascii "VLAN-A:3"
option 128 ascii "Nortel-i2004-A,10.2.100.200:4100,1,5."
lease 0 2
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode access
switchport voice vlan 3
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 3
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport access vlan 2
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
spanning-tree guard root
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.2.100.1 255.255.255.0
interface Vlan2
no ip address
interface Vlan3
ip address 10.2.110.1 255.255.255.0
Solved! Go to Solution.
05-28-2010 10:51 PM
You don't need an IP helper address on the switch.
A IP phone send out a dhcp discover on de DATA vlan first.
So you have to move the vlan option, in your case option 191, to the DATA scope. The IP phone will see this option when it get's an IP address of the DATA scope. Then it will release the IP address and sends out a discover in the VOICE LAN. Then it will get an IP address of the VOICE scope and will recognoze option 128 to find out where the nortel systems are.
This is normal behaviour of an IP phone.
There are other techniqs to iplement IP phones on the network,Like LLDP-MEDfor example.
The IP phone has to support those techniqs
HtH
Michel
05-28-2010 06:01 PM
Since vlan 3 is your voice vlan, under this vlan add this command:
interface Vlan3
ip helper-address (address)
Reza
05-28-2010 08:14 PM
Hi:
What address in helper-address, i don't understand, it's not the helper-address for a external DHCP Server ?
05-28-2010 08:23 PM
Find out your DHCP's IP address. That would be the helper-address
05-28-2010 08:48 PM
Hi:
I want setup the dhcp server on my c3560.
ip dhcp pool voice
lease 0 2
The same switch will be the dhcp server
interface Vlan3
So which would be my helper-address i don't get it.
05-28-2010 10:51 PM
HtH
Michel
05-31-2010 08:54 AM
That's the way it works.
A lot of thanks..
04-29-2013 02:48 AM
Hi ,,
kindly could you advise me with the following :
- my Equipment is :
1- Cisco voice Router 2901 (IOS Version 15.0 and telephony version is 8.6)
2- HP Managed Switch V1910-24G PoE(365W) JE007A
3- Nortel ip Phones 1140e
my setting :
- On Cisco router :
1- DHCP Pool :
ip dhcp pool KSA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.200
option 150 ip 192.168.1.200
2- Configure Extension :
voice register global
mode cme
source-address 192.168.1.200 port 5060
max-dn 20
max-pool 20
authenticate realm cisco.com
tftp-path flash:
create profile sync 0001040727941127
voice register dn 1
number 105
allow watch
name user
label user
voice register pool 1
registration-timer max 200 min 100
id mac 001B.252F.ECA9
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 1112 password 1112
- on ip Phone :
i give the ip phone ip address from the same router and determine Server1 as 192.168.1.200 which is Cisco router and 5060 port
- on HP Switch :
i make a voice Vlan (Vlan ID is 3) and connect all my eqiupment to this Vlan (Nortel ip Phone plus router plus cisco ip phones)
my case is i need to connect the nortel ip phone 1140e to be as Extension from cisco routers.so can you help me plz??? is this way the right way???!!!
