c3560 switch
what is the back plane of a c3560 switch?
1 ACCEPTED SOLUTION
Re: c3560 switch
• 32 Gbps forwarding bandwidth
• Forwarding rate based on 64-byte packets:
• 38.7 Mpps (Cisco Catalyst 3560G-48TS, Catalyst 3560G-48PS, Catalyst 3560G-24TS, and Catalyst 3560G-24PS);
• 13.1 Mpps (Cisco Catalyst 3560-48TS and Catalyst 3560-48PS);
• 6.5 Mpps (Cisco Catalyst 3560-24TS and Catalyst 3560-24PS);
• 2.7 Mpps (Cisco Catalyst 3560-8PC)
From this doc:
http://cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Hope this helps. If so, please rate the post.
Brandon
Re: c3560 switch
From this doc:
Brandon
Re: c3560 switch
Thats what I read also. so does this mean if I get the 3560 48 TS which I think is 10/100mg then the backplane is 13.1Mpps?
Hall of Fame Super Blue
Re: c3560 switch
The 32Gbps figure is the one you are interested in. This is in effect the switch fabric available on the switch. As you have 48 10/100 ports then you should not get oversubscription ie. it should be non-blocking.
If you had a 10/100/1000 48 port 3560 then you would get oversubscription on the switch fabric.
Jon
291
