C3750-24FS random port shutdown
I'm in the process of deploying c3750-24FS switches for workstation access. They are running adventerprise 122-40SE IOS. On a very random basis ports will lockout and will only allow the client access if the switch is reloaded. It's only happening to around 1 client in 20. As the network is still in the deployment phase there is no configuration on the access ports other than it's VLAN and portfast. I've tried to replicate the problem in a lab, but to no avail. Has anyone had any similar problems or ideas on solving the issue.
Bronze
Re: C3750-24FS random port shutdown
What are the various "sh" commands for the interface(s) saying? Particularly:
sh int
sh int switchport
sh port-security int
It happens on all the switches? shut/no shut doesn't clear it?
sh int
FastEthernet2/0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001f.9e85.f883 (bia 001f.9e85.f883)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseFX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
982 packets input, 225300 bytes, 0 no buffer
Received 9 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
3425 packets output, 675393 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
FastEthernet2/0/3 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001f.9e85.f885 (bia 001f.9e85.f885)
Last input never, output 00:00:00, output hang never
3639 packets input, 721328 bytes, 0 no buffer
Received 58 broadcasts (0 multicasts)
5798 packets output, 1169460 bytes, 0 underruns
When this was taken port one client machine was up and port three was locked out, but no error messages, no syslog and ports show as up.
164
