C3750-IPSERVICES-M question
I have a switch with the C3750-IPSERVICES-M image on it. I thought this would allow me to do layer 3 stuff but I can't seem to enable eigrp routing. What image should I use if I need routing capabilities?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: C3750-IPSERVICES-M question
Roland
IPServices should support full EIGRP. What happens when you configure
3750(config)# router eigrp 1
You have enabled ip routing on the switch ? ie.
3750(config)# ip routing
Jon
Roland
Jon
Crud...I forgot to enable ip routing! Thanks Jon!
Roland
No problem. If i had 5 points for every time i forgot this sort of thing i'd be up there with Rob :-)
Jon
1160
