Community Member
C3750: Packets lost
Dear all,
I hope any of you can help me, or give me an idea where to look ...
I have a stack of 2 C3750-switches (WS-C3750G-24TS-1U) with IPBASE-firmware (12.2(52)SE).
When I ping to a machine (in this case a virtual one), the replies are always received on the port where the machine is connected, but on the port-channel connecting to the stack of the 'pinging device' the reply comes only for certain initiators, and not for all.
Setting:
Gi1/0/6: Device/Server I want to connect too ; defined as access port
Gi1/0/25 + Gi2/0/25, as Port-Channel 1: The location of the devices I connect (read as: the uplink to the stack of the PC's), defined for Dot1Q-trunking
Monitoring setup: Source ports: Both: Gi 1/0/6, Po1 (or Po1 replaced by both interfaces)
For the machines which can ping the server I see 2 echo (ping) requests, followed by 2 echo (ping) replies ... So once seen on the Po1, and once seen on the interface Gi1/0/6.
However for other machines, the 2nd reply is missing ; which must be caused by the dropping of these packets in the switch.  At least, I my opinion this must be the reason... But I can't see any (change of) output drops at int Po1, nor at Gi1/0/6.  The CPU doesn't seem to have high usage, and even then, I don't think the error would be constant, as it's always failing for some PC's, and never for others... (at least for a certain time, a few hours it can be constant, the problem dissapears from time to time).
I can't think of any filtering applied in the switch, but of course there must be a reason... I looked through the config a lot of times, searched the internet, but nothing has made me any wiser ...
Can anyone give me some info where I have to look for a solution to this problem?
PS: I know this is older firmware, but as we don't have a maintenance contract anymore, we can't download newer firmware...And even then, if it wouldn't be a problem related to a firmware-bug, I don't think I would make the upgrade.
Alain
Everyone's tags (1)
1 REPLY
C3750: Packets lost
Hello Alain,
I have few questions to understand it better.
- what is speed on Gi1/0/6
- what are the ip addresses of "inging devices" which work and which do not - are they in same subnet
- Do you have ARP/MAC values for "piniging devices" which do not work on 3750 stack
Please also get the following commands:
- show controller eth gi1/0/6
- show controller eth gi1/0/25
- show controller eth gi2/0/25
for same interfaces:
- show queueing int Gix/y/z
- show int gix/y/z switching
- show platform port-asic stats drop interface gigx/y/z
- show ip traffic
Nik
362
