03-02-2007 07:15 AM - edited 03-05-2019 02:40 PM
Appreciate help on the following boot up error:
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3750-ipbasek9-mz.122-25.SEE2.bin"...flash:c3750-ipbasek9-mz.122-
25.SEE2.bin: no such file or directory
Error loading "flash:c3750-ipbasek9-mz.122-25.SEE2.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
Could someone advise me the steps or send me the relevant links?
do I need to do a xmodem since the flash:c3750-ipbasek9-mz.122-25.SEE2.bin is not found?
Christina
03-02-2007 07:38 AM
If you do a "dir flash: " does it show any images ? If so then add a boot statement to match image in flash . "boot system flash:
03-02-2007 07:53 AM
Before going for the xmodem option do a dir flash: just as what Grant has suggested. See if you have any bootable images present in your flash. If it is present then do a boot flash:
It should boot up. But if you have no images in your flash, then follow this link for xmodem recovery. http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Hoogen
