C3750E-48PD stack unstable
End user has two new 3750E switches. At the begining were working fine  but suddenly loggs began showing  the following messages
ar 24 17:32:02: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
Mar 24 17:32:03: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
Mar 24 17:32:33: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
Mar 24 17:32:34: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
Mar 24 17:35:15: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
Mar 24 17:35:16: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
Mar 24 18:01:35: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
Mar 24 18:01:36: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
Mar 24 17:32:02: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
I have powered down both switches and checked stack cables connection, but the problem remains.
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750E-48PD     12.2(52)SE            C3750E-UNIVERSALK9-M
     2 54    WS-C3750E-48PD     12.2(52)SE            C3750E-UNIVERSALK9-M
What else can I checked in order to clear this issue?
regards
9 Replies 9
Leo Laohoo
Make sure the stack cables are secure.
Judging from the error messages, looks like Switch #2 is faulty.
Tirumala Earla
With help of # show switch detail command you can see the status of the stack cable connetivity. Please verify and put output for reference.
Hi Tirumala,
This is the output I got some minuetes ago,
COREP5#      sh switch detail
Switch/Stack Mac Address : 0c85.25c3.9400
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0c85.25c3.9400     10     1       Ready
2       Member 0c85.25c2.b480     1      1       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
                                           H/W   Current
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
                                           H/W   Current
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
                                           H/W   Current
  1        Ok         Ok                2        2
  2        Ok        Down             None     None    ------------>>>  sometimes DOWN
                                           H/W   Current
  1        Ok         Ok                2      None  --------------------------------------->>> ????
  2        Ok         Ok                1        1
COREP5#
                                           H/W   Current
  1        Ok         Ok                2        2
  2        Ok         Ok              None     None   ---------->>>>>> ??????
                                           H/W   Current
  1        Ok         Ok                2      None   ---------->>>????
  2        Ok        Down               1      None  --->>>>>>???
COREP5#
Judging from this latest output, my initial recommendations are still the same:
1.  Have you check to ensure all four cable sockets are firmly secure to each stack port?
2.  Stack member #2 is failing.  You could try a disruptive test if wish.   Command is:  diagnostic start switch 2 test all
WARNING:  This is a DISRUPTIVE test.
Post the output to the command "sh diagn result switch 2".
Hi Leo,
Thanks a lot for your interest in this issue.
I have already checked several times all cable sockets. I powered off both switches and disconnected  cables,  then connect once again firmly secure.
Because of is a DISRUPTIVE test I need to try in no working hours.  :-(
regards
Thanks.  I await for your response and result.
May I also ask you to post the output to the command "sh post" please?
Hi leo,
I send you the sh post info:
I'm waiting the maintenance windows in order to get the info you asked me.
I really appreciate your time and help.
COREP5#sh post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
Switch 2
COREP5#
Hmmm ... "sh post" looks good.  We'll see after the diagnostics.
