Community Member
C3750e dropped AF41 traffic in ingress interface
Hi all,
As above, I got a problem with C3750e, ios c3750e-universalk9-mz.122-58.SE1.bin, when send AF41 traffic passing through it. My topolygy is as following
WAN link <----------> G0/0/2.100 - ASR1002 - G0/0/5 <---------> G1/0/1 - C3750e - G1/0/3 <--------> G0/0/1 - ASR1004
On this C3750e, I turned on mls qos, trust dscp on both G1/0/1 and G1/0/3 and no else is configured. ASR1002 G0/0/2.100, i applied the CB shaping fror AF41 traffic.
C3750e#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
C3750e#sh mls qos int g1/0/3
GigabitEthernet1/0/3
trust state: trust dscp
trust mode: trust dscp
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
C3750e#sh mls qos int g1/0/1
GigabitEthernet1/0/1
COS override: dis
default COS: 0
Trust device: none
C3750e#sh mls qos maps dscp-input-q
   Dscp-inputq-threshold map:
     d1 :d2    0     1     2     3     4     5     6     7     8     9
      0 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
      1 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
      2 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
      3 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
      4 :    02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 01-01 01-01
      5 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
      6 :    01-01 01-01 01-01 01-01
C3750e#sh mls qos int g1/0/3 queueing
Egress Priority Queue : disabled
Shaped queue weights (absolute) :  25 0 0 0
Shared queue weights  :  25 25 25 25
The port bandwidth limit : 100  (Operational Bandwidth:100.0)
The port is mapped to qset : 1
C3750e#sh mls qos map dscp-mutation
   Dscp-dscp mutation map:
   Default DSCP Mutation Map:
     d1 :  d2 0  1  2  3  4  5  6  7  8  9
      0 :    00 01 02 03 04 05 06 07 08 09
      1 :    10 11 12 13 14 15 16 17 18 19
      2 :    20 21 22 23 24 25 26 27 28 29
      3 :    30 31 32 33 34 35 36 37 38 39
      4 :    40 41 42 43 44 45 46 47 48 49
      5 :    50 51 52 53 54 55 56 57 58 59
      6 :    60 61 62 63
Then, from ASR1004, i send ICMP traffic with TOS set to AF41 (136) and i found out that
1. The traffic is dropped on c3750e
sh mls qos int g1/0/3 statistics
GigabitEthernet1/0/3 (All statistics are in packets)
30 - 34 :          63           63           48           86         1534
2. The traffic never get hit into AF41 class in ASR1002
May I seek for Guru's advise why C3750e dropped this AF41 traffic? and what can I do to fix it?
Appreciate your prompt advice
1 REPLY
Hello Nhat,
Have you confirmed drops are seen in q4 (dscp 34)?
Can you send me the complete output of sh mls qos int g1/0/3 statistics, maybe two or three instances?
Fabienne
TAC
398
