C3750G-16: No route to specific subnet, while route to individual addresses works
Hello there!
I have Catalyst C3750G switch
with configured route to subnet 192.168.201.0/24
ip routing
ip route 192.168.201.0 255.255.255.0 192.168.160.13
192.168.160.13 is accessible
sw12-3750G-TD16-1#ping 192.168.201.82
Sending 5, 100-byte ICMP Echos to 192.168.201.82, timeout is 2 seconds:
Success rate is 0 percent (0/5)
sw12-3750G-TD16-1#
but if add the next line this node starts respond
ip route 192.168.201.82 255.255.255.255 192.168.160.13
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
sw12-3750G-TD16-1#
what is problem? please, help
Sincerely, Alexey
Purple
to decide which entry to use  in the RIB to forward a packet the router chooses the longest match.
Can you provide output of sh ip route 192.168.201.0 255.255.255.0 before configuring the host route.
Regards.
Alain
Alain is right. Just to add, there is a chance that you may already have a longest match route pointing to another gateway. May be something like this
ip route 192.168.201.0 255.255.255.128 X.X.X.X
X.X.X.X could be some other gateway.
your show show ip route output may provide the answer. Will wait.
Vivek
sw12-3750G-TD16-1#sh ip route 192.168.201.0
Routing entry for 192.168.201.0/24, 3 known subnets
  Attached (2 connections)
  Variably subnetted with 2 masks
C        192.168.201.0/24 is directly connected, Vlan10
L        192.168.201.12/32 is directly connected, Vlan10
S        192.168.201.82/32 [1/0] via 192.168.160.13
I forgot mention one thing: this switch had  vlan 10 with 192.168.201.12 address, if remove vlan 10 with its address from 3750G, ping works as it should: it pings all VLAN nodes in 201.0
interface Vlan10
ip address 192.168.201.12 255.255.255.0
Purple
if the /24 is a connected route then it will have an AD of zero and it will win against the static route with an AD of 1
Can you provide a diagram explaining what you are doing.
Regards.
Alain
Yes, i will prepare all materials and descriptions at Monday.
319
