Webcast-Catalyst9k
C3KX-NM-10G port not working
3560X is connected to another 3560X by 10G fiber optic connection (C3KX-NM-10G network module, SFP-10G-LRM on both ends).
Yesterday 10G port went down. After changing SFPs, cables I am sure one of the 10G ports on network module is not working, it does not work with tested SFPs and cables.
sh inventory command output
NAME: "FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G ST Module"
PID: C3KX-NM-10G       , VID: V01  , SN:
NAME: "TenGigabitEthernet1/1", DESCR: "SFP-10GBase-LRM"
PID: SFP-10G-LRM         , VID: V02  , SN:
NAME: "TenGigabitEthernet1/2", DESCR: "SFP-10GBase-LRM"
sh ip int brief
TenGigabitEthernet1/1  10.1.1.90       YES manual down                  down
TenGigabitEthernet1/2  10.1.1.10       YES manual up                    up
What can I try in this situation? Or RMA is the only option?
TIA
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
What is your IOS?  Can you
What is your IOS?
Can you also post the output to the command "sh post"?
Try upgrading to 12.2(55)SE9
Try upgrading to 12.2(55)SE9 and try again.
Hall of Fame Super Silver
From how you describe it, an
From how you describe it, an RMA may well be in order. The TAC is pretty good about that sort of thing.
What does "show int te1/1 transceiver detail" show you?
Hi,Output from both working
Output from both working and non working ports:
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te1/1       40.8                75.0        70.0         0.0       -5.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te1/1      3.27                  3.63        3.46        3.13       2.97
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te1/1       -2.1                 3.5         0.5        -6.5      -10.5
           Receive Power      Threshold   Threshold  Threshold  Threshold
Te1/1       -2.0                 3.5         0.5        -8.0      -12.4
SR1_C3560X_24_10#sh int te1/2 transceiver detail
Te1/2       40.5                75.0        70.0         0.0       -5.0
Te1/2      3.26                  3.63        3.46        3.13       2.97
Te1/2       -2.1                 3.5         0.5        -6.5      -10.5
Te1/2       -3.1                 3.5         0.5        -8.0      -12.4
What is your IOS?
HI, IOS version c3560e
HI,
IOS version c3560e-universalk9-mz.122-55.SE3.bin
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
Thank you. Port is up after
Thank you. Port is up after upgrading.
Thanks for taking the time
Thanks for taking the time for updating the results.  :)
I'm also having this exact
I'm also having this exact same problem on the same code version. Planning to upgrade this weekend.
This thread is >1 year now.
This thread is >1 year now.  There are newer versions to the 12.2(55)SE train, namely 12.2(55)SE10.  I'd recommend you use whatever latest there is available.
Upgraded to 12.2(55)SE10 with
Upgraded to 12.2(55)SE10 with same results. Might try a 15 release but I'm leaning towards a hardware issue on the module. This is a fairly new module installed (<2 months).
Following up - Cisco sent a
Following up - Cisco sent a replacement module which seems to have resolved my issue.
385
