C3KX-NM-10GT module not showing link activity.
We have a stack of 5 Cisco 3560x switches. Switch 1 has a C3KX-NM-1G expansion module all 4 ports are populated and functioning normally. Switch 2 has a C3KX-NM-10G module which has one 10G port populated and working. We just added a C3KX-NM-10GT module to switch 3 which is connected to a server. We are not seeing any link activity on the 10GT module. I have confirmed that the NIC it is connected to is working. I restarted the switch yesterday and the lights on the module flashed during the restart but still no activity. Any help would be greatly appreciated.
1 ACCEPTED SOLUTION
James,
Whats the firmware version running on your device?
Note:
If this C3KX-NM-10GT is installed in your C3560/c3750 switch, then according
to the release-notes you need a minimum of IOS release 15.0(1)SE
installed to support this module:
"C3KX-NM-10GT
10-Gigabit Ethernet Network Module
Two 10-Gigabit Ethernet (copper) ports.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/release/notes/OL25302.html
Inayath
*****Please rate all usefull posts**************
James,
Just curious to know what happen if you connect 10GT to another 10G module of Switch 2(Switch 3---Switch 2 module)?
Does this work as this test would eliminate the fault with the 10Gig module.
If the link comes up then there is no issue with the module. If not then you the module might be faulty.
Inayath.
The other 10G is fiber the 10GT is copper. Ther is no way to connect the two. I could try the Module in another switch.
Tried the Module in another switch with the same result no activity lights.
James,
Note:
"C3KX-NM-10GT
Inayath
I believe you have nailed it my friend. The version currently installed is 12.2 which according to the matrix won't cut it. I will upgrade to the latest release. Thanks for the help.
Happy to hear that.
Could you mark this thread as answered as this would help others if they have same query .
Inayath
***** Plz rate all usefull posts*****************
337
