Community Member
C3KX-PWR-1100WAC= compatible with WS-C3750X-24P-S?
Is the C3KX-PWR-1100WAC= compatible with the WS-C3750X-24P-S?
1 ACCEPTED SOLUTION
Gold
Yes it is compatible.
Just note that the 1100wac powersupply sticks out a bit from the chassie about 3-4 cm.
Good luck
1 REPLY
Gold
Good luck
327
