Community Member
c4506L-E,there is only one supervisor,(Peer supervisor not detected or is not running IOS).bad,the WS-X4612-SFP-E was displayded "Unsupported module".
Is there any question with hardware about the WS-X4612-SFP-E modle.thanks
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
is there any question about "config-register = 0x2101".thanks.
No.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(53)SG4, RELEASE SOFTWARE (fc2)
Your IOS does NOT support the WS-X4612-SFP-E line card.  Upgrade to 12.2(54)SG or later.
If the solution works, can I request if you can mark this thread as "Answered" please?
C'mon, mate.  You need to give us more info than this!
You need a minimum of Cisco IOS Software Release 12.2(54)SG or later.
Community Member
* Welcome to Rom Monitor for WS-X45-SUP6L-E System        *
* Copyright (c) 2003-2011 by Cisco Systems, Inc.         *
* All rights reserved.                                   *
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
Rom Monitor Program Version 12.2(44r)SG10
CPU Rev: 2.1, Board Rev: 12, Board Type: 103, CPLD Nexu Rev: 14
Chassis: WS-C4506-E
Front Panel Phy is Bcm5482s
Got Mac Address: 30:e4:db:fd:ac:e1
MAC Address  : 30-e4-db-fd-ac-e1
Ip Address   : Not set.
Netmask      : Not set.
Gateway      : Not set.
TftpServer   : Not set.
Supervisor uplinks and all linecards have been reset
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
Autobooting using the first file from bootflash.....
sho ver
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Fri 25-Feb-11 15:14 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x124334BC
ROM: 12.2(44r)SG10
Darkside Revision 4, Jawa Revision 14, Tatooine Revision 140, Forerunner Revision 1.21
Switch uptime is 1 minute
System image file is "bootflash:cat4500e-ipbase-mz.122-53.SG4.bin"
cisco WS-C4506-E (MPC8548) processor (revision 12) with 524288K bytes of memory.
Processor board ID SPE152800QF
MPC8548 CPU at 1GHz, Supervisor 6L-E
Last reset from PowerUp
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
--More--
--More--                           Configuration register is 0x2101
sho mod
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup 6L-E 10GE (X2), 1000BaseX (SFP)    WS-X45-SUP6L-E     JAE15300DRW
3    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE153805FF
5     0  Unsupported module                     WS-X4612-SFP-E     JAE15330C0I
M MAC addresses                    Hw  Fw           Sw               Status
1 30e4.db27.e840 to 30e4.db27.e845 3.0 12.2(44r)SG1 12.2(53)SG4      Ok
3 ccef.483a.c89c to ccef.483a.c8cb 1.0                               Ok
5 7081.0556.0fa0 to 7081.0556.0fab 1.1                               Unsupport
Community Member
No.
Community Member
thanks,i'll try.
Community Member
ok,thanks!
Cool!  I'm happy to see the solution works.
1912
